px125e:
S p e c s: VNX2T
1981 - 1984
engine: single cylinder, air cooled 2-stroke
induction: disc valve
bore: 52.5 mm
stroke: 57 mm
cubic capacity: 123.4 cc
compression ratio: 8.2: 1
bhp at rpm: 7.5 @ 5750
lubrication: 2%(USA autolobe)
transmission: 4 speed constant mesh
1st gear: 16.43: 1
2nd gear: 10.98: 1
3rd gear: 7.60: 1
4th gear: 5.83: 1
clutch: wet - multiplate
carburetor: Dell'Orto SI 20/20 D
venturi size: 20 mm
main jet: 99/100
slow running jet: 140/100
throttle valve: 6823.08
mixer tube: BE 5
atomiser: 280/100
starter jet: 60/100
ignition: electronic
ignition timing: 18 deg. BTDC
spark plug: NGK - B6HS
spark plug gap: 0.6 mm
voltage: 12 volt
wheels: 10"
wheel hubs: cast w/cooling fins
tires: 3.50 x10
tire pressure (front): 18 psi
tire pressure (rear solo): 26 psi
tire pressure (rear w/passenger): 36 psi
max speed: 56 mph
total dry weight: 229 lbs
px150e:
S p e c s: VLX1T
1981 - 19??
bore: 57.8 mm
stroke: 57 mm
cubic capacity: 149 cc
1st gear: 14.47: 1
2nd gear: 10.28: 1
3rd gear: 7.31: 1
4th gear: 5.36: 1
venturi size: 20 mm
main jet: 116/100
slow running jet: 160/100
throttle valve: 6823.01
mixer tube: BE 3
atomiser: 280/100
starter jet: 60/100
ignition timing: 21 deg. BTDC
voltage: 12 volt
1st gear: 16.43: 1
2nd gear: 10.98: 1
3rd gear: 7.60: 1
4th gear: 5.83: 1
150:
1st gear: 14.47: 1
2nd gear: 10.28: 1
3rd gear: 7.31: 1
4th gear: 5.36: 1
